Design SuiteCreating a horizontal section viewport
Command
Path
Create Horizontal Section Viewport
Create Section Viewport (clip cube)
View
Context menu (clip cube)
Horizontal section viewports create a cross-section view of a model that can be customized in several different ways, as outlined in Creating section viewports.
To create a horizontal section viewport:
Prepare to create the viewport as follows:
To create a section view from a design layer, make the design layer active.
To create a section view from an existing viewport, either select a non-sectioned viewport object in Top, Bottom, Left, Right, Front, or Back view orientation, or edit the annotations of a non-sectioned viewport.
To create a section view from an existing clip cube object, use the Selection tool to highlight a horizontal face of the clip cube where the section will begin. See Viewing a model with the clip cube.
Select the command.
The Create Horizontal Section Viewport dialog box opens. The available parameters depend on whether you choose to place the section viewport on a sheet layer or design layer. The parameters set by instance can be edited later from the Object Info palette or by right-clicking on the viewport and selecting Properties from the context menu.
The scale of a design layer section viewport is the same as the layer where it is placed. The rendering mode of the current layer is also used to render the design layer section viewport.
Parameter
Description
Style Name
From the Resource Selector, double-click a resource to activate it, or click Unstyled. If a styled object is converted to unstyled, the current values are retained, but all parameters are set to By Instance to allow editing.
By Style/Instance
A graphic indicates whether each parameter that can be set by the viewport style is set to By Style and given a fixed value or set to By Instance and editable in the dialog box. A style may have a combination of both settings, to balance the need for consistency and flexibility. Certain parameters must be set by instance, and are not subject to these settings.
By Style/Instance settings are established by the style and cannot be changed from this dialog box.
To edit the style, see Creating and editing viewport styles; editing the style modifies all viewports in the file that use that style.
General Settings
Name viewport as Dwg No./Sheet No.
(Sheet layer only)
Select this option to automatically set the Viewport Name to be a combination of the Drawing Number and the Sheet Number assigned to this viewport.
Deselect this option to enter a custom Viewport Name.
Viewport Name
If Name Viewport as Dwg No./Sheet No. is not selected, enter a descriptive name for the viewport; this name must be unique in the document
Create on Layer
Select the layer where the viewport will be created, or select New [Sheet or Design] Layer to create a layer. If there are no sheet layers present and a new one is not created now, you'll be prompted to create a sheet layer after clicking OK.
Use drawing label
(Sheet layer only)
Creates a drawing label in the annotation space of the viewport; select the style from the Resource Selector
Drawing Number
(Sheet layer only)
The next sequential drawing number available on the selected Sheet Layer defaults automatically. This number displays on the section marker, as well as on annotation objects in or linked to this viewport. This number must be unique on this sheet layer.
Drawing Title
(Sheet layer only)
Specifies a descriptive title for the viewport, up to 63 characters. The title displays for annotation objects in the viewport.
If Use Automatic Drawing Coordination is selected in document preferences, a change to this field for the viewport automatically changes the field for the viewport’s drawing label, and vice versa.
Layers
Specifies which design layers are visible in the viewport; see Visibility columns. When editing viewport properties or creating/editing a viewport style, allows changes to some of the layer properties in the viewport; see Changing the layer properties of sheet layer or design layer viewports.
Classes
Specifies which classes are visible in the viewport; see Visibility columns. When editing viewport properties or creating/editing a viewport style, allows changes to some of the class properties in the viewport, including changes to the properties for annotation or crop objects. Class visibilities can be overridden for a selected viewport; see Changing the class properties of sheet layer or design layer viewports.
Phasing
Available only when there is more than one phase in a file
Phase
Select the phase to display in the viewport. The selected phase becomes the active phase for the viewport.
Show as Low Detail
Depending on the selected options, displays component-based objects (such as walls, slabs, roofs, and hardscapes) and/or symbols and plug-in objects with an active phase status of Existing or Removed/Demolished in low detail, regardless of the viewport's current detail level setting
Data Visualization
Applies a data visualization to the viewport, to hide objects or change object attributes based on object data; see Viewing the drawing by data or by attributes
Create data visualization legend
Automatically adds a data visualization legend whenever a data visualization is applied to the viewport
Scale
(Sheet layer only)
Specifies the viewport scale relative to the page; select a scale, or choose Custom and enter a Custom Scale value
Detail Level
Select the detail level for symbols and plug-in objects in the viewport; see Customizing detail levels for 2D and 3D components of symbol definitions and plug-in objects.
Wall, slab, and roof components display at settings Medium and High.
Display planar objects
Displays 2D planar objects; visible planar objects are sectioned if positioned at the section line
Display 2D components
Displays 2D components (when available) for symbols and plug-in objects positioned normal to the view; see Concept: 2D components for symbol definitions and plug-in objects. When the object has no 2D component for the view, the 3D component displays.
For viewports on design layers, when Display flattened is selected, the behavior is the same as for sheet layers. When Display flattened is deselected, the viewport displays 2D components only within the cut graphics.
This applies only to viewports with hidden line rendering and set to a 3D view in orthogonal projection.
Display flattened
(Design layer only)
Always displays a “flattened” section view, similar to a section viewport on a sheet layer; deselect this option to have the viewport display the current view selected for the design layer
Display Settings
Cut Plane
Displays the cut plane height, which is set in the Cut Plane and Extents dialog box
Relative to
Displays to which layer, story, or story level the cut plane height is relative, which is set in the Cut Plane and Extents dialog box
Opens the Cut Plane and Extents dialog box to control the height of the cut plane and the depth of the extents below and above the cut plane; see Setting horizontal section viewport cut planes and extents
Display extents below cut plane
Displays objects below the section cut plane; visible planar objects are sectioned if positioned at the section line
Background/Foreground Render
Background Render specifies the render mode for the viewport. For a composite, sketch-like effect, creating an overlay of lines on top of the viewport, also select an optional foreground mode (Wireframe, Sketch, Hidden Line, or Dashed Hidden Line are the only render modes available for foreground rendering).
Some modes enable the Background/Foreground Render Settings, to specify rendering parameters. If a render style is selected for the background render mode, it controls the background render settings; see Render styles.
For design layer section viewports, the background render mode is set by the design layer's setting, and Foreground Render is available only when Display flattened is selected.
Available when the selected rendering mode requires parameters to be set. Shaded and Hidden Line render modes provide additional depth cueing options when accessed from the Object Info palette of a selected viewport. See the following:
Shaded settings: Shaded options and Showing depth in a viewport
Custom Renderworks settings: Custom Renderworks options
Artistic Renderworks settings: Artistic Renderworks options
Hidden Line, Dashed Hidden Line, and Final Shaded Polygon settings: Line render options and Showing depth in a viewport
Sketch settings: Applying sketch styles to viewports
Display 2D fills
(Sheet layer only)
When Background Render is set to Hidden Line or Dashed Hidden Line, displays 2D fills for visible planar objects below the cut plane; see Fill attributes. 2D fills also display for 2D components, when applicable.
RW Background
(Sheet layer only)
Available if the Background Render mode is a Renderworks mode.
If a render style is selected, but no RW Background options are available, the background is controlled by the style; see Render styles.
Hidden Object Display
Opens the Hidden Object Display by Class dialog box to set the display and pen attributes for objects below the cut plane that are obscured by other objects; see Displaying 3D objects by class in section viewports.
This option is available for design layer section viewports only when Display flattened is selected.
Display extents above cut plane
Displays geometry above the cut plane.
Object Display
Opens the Object Display by Class dialog box to set the display and pen attributes for objects above the cut plane; see Displaying 3D objects by class in section viewports.
Opens the Hidden Object Display by Class dialog box to set the display and pen attributes for objects above the cut plane that are obscured by other objects; see Displaying 3D objects by class in section viewports.
Projection
(Sheet layer only)
Select the projection type for the viewport (see Projection)
Perspective Type
(Sheet layer only)
For Perspective projection, select the type of perspective, or choose Custom and specify the Perspective Dist (distance)
Advanced Section Properties
Specifies advanced section viewport parameters defining the extent and attributes of the section view; see Advanced section viewport properties
The new horizontal section viewport is displayed.
For a viewport placed on a design layer, the view is initially set to Top/Plan, but the section can be displayed in any view. A design layer section viewport can be cropped, but it does not contain an annotation space.
Optionally, create a style resource from an unstyled object. See Creating and editing viewport styles.
Creating a vertical section viewport
Viewport properties
Viewport styles
Modifying viewports
Viewport status
Updating viewports
